Thickness calipers http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=10964 |
Author: | Andy Matthews [ Fri Feb 16, 2007 10:49 am ] |
Post subject: | |
Well, I need some. I've been using the ones at college up until now, but I won't have that option much longer! What do you guys used? Home made? Shop bought? Pictures/tips for home made ones would be much appreciated. Likewise links to cheap suppliers of the proper thing ![]() |
Author: | Dave Rector [ Fri Feb 16, 2007 11:30 am ] |
Post subject: | |
I just use a pair of digital calipers that I picked up at Harbor Freight. I think they were about $25.00 |
Author: | Dave Rector [ Fri Feb 16, 2007 11:31 am ] |
Post subject: | |
Oops, sorry Jammy, I didn't realize before posting that you were in the U.K. I would just do a google search for digital calipers and see what is available on your side of the pond. |
Author: | crazymanmichael [ Fri Feb 16, 2007 11:45 am ] |
Post subject: | |
there are some photos in the archives. all one needs are a cheap dial indicator, a carriage bolt, and a plywood or metal horseshoe shaped frame. if you can i would recommend that you get a set of alternative tips for the dial indicator. a wide curved or flat one works better than the small round one which comes standard. on thie side of the pond enco sells the indicator with the set of alternative tips for about $12.00 |
Author: | Irwin R [ Fri Feb 16, 2007 2:10 pm ] |
Post subject: | |
I made my own from a couple pieces of MDF and a thickness dial indicator, I wish I'd taken my time a lttle more
I couldn't see myself spending the money at the time for a professional one, but Stewmac has one for sale now a little cheaper than when I made mine.. I think it took me about 1/2 hr to make . I'm sure you'll see some nicer home mades!
Cheers |
Author: | Arnt Rian [ Fri Feb 16, 2007 6:30 pm ] |
Post subject: | |
I made one that is similar to Irwin's. Since you're in the UK you could get your dial gauge from Axminster, assuming you want metric. I got one of those, and it works well. |
Author: | Colin S [ Fri Feb 16, 2007 7:50 pm ] |
Post subject: | |
Jammy, Arnt is right you can get dial guages from Axminster, or if you just Google them you'll find plenty of UK suppliers. I made my own thickness gauge many years ago, took about half an hour including varnishing the wood. ![]() AS you can see just a U cut from thick plywood with the dial gauge and a bolt with the end rounded off. I like the fact that it can be held securely in a vice and the board just run between the opening. Colin |
Author: | crazymanmichael [ Sat Feb 17, 2007 2:11 am ] |
Post subject: | |
if you use a carriage bolt the smooth rounged head makes a very good anvil surface for the stock to ride on and avoids the extra work of rounding the threaded end. one tip; drill your mounting holes using a fence and a positioning stop before you cut out the inside of your horseshoe. makes for more accurate concentricity of your gauge and anvil. |
Author: | KiwiCraig [ Sat Feb 17, 2007 9:57 am ] |
Post subject: | |
![]() I made this a few years ago with scrap I had lying around . It's completely over the top , ,,,I know ![]() I have it graduated in metric and it has many adjustments to recallibrate . Had a lot of fun building it ,and it always puts a smile on my dial when I use it. Craig Lawrence |
Author: | Kim [ Sat Feb 17, 2007 12:11 pm ] |
Post subject: | |
Author: | Arnt Rian [ Sat Feb 17, 2007 8:07 pm ] |
Post subject: | |
Craig, that it fantasitc! Detail pictures please! |
Author: | Billy T [ Sat Feb 17, 2007 8:20 pm ] |
Post subject: | |
Craig! That is so Cool!!! Like Arnt said, some close in shots would be great! |
Author: | KiwiCraig [ Sun Feb 18, 2007 10:03 am ] |
Post subject: | |
Cheers guys. I haven't any detailed pics here at the moment . I'll try and arrange some . |
Author: | Martin Turner [ Sun Feb 18, 2007 11:19 pm ] |
Post subject: | |
Mate that thickness guage should be in the National Art Gallery ![]() |
